HaloCode/CyberPi AI & IoT Scientist Add-on Pack (5 PCS Limited)
Sold Out
    $126.00 $259.99
      PAYMENTS payment icons
      AI & IoT Scientist Add-on Pack comes with 13 mBuild's electronic modules and 9 accessories packs, including Speaker, Motor, LED Strip, LED Ring, LED Matrix, Fan, Ranging Sensor, PIR Sensor, Dual RGB Sensor, Angle Sensor, Extend Block and Rechargeable Lithium Battery.
      Note:  The pack doesn't includes mainboard. It must work with HaloCode, CyberPi or mBuild-compatible electronic modules.
      Part List:
      • Speaker
      • Power
      • 2 x Motor Driver, 2 x Motor Pack, Water Pump Pack
      • Ranging Sensor
      • Servo Driver, Servo Pack
      • LED Matrix
      • Slider
      • LED Driver, 2 x LED Strip Pack, 2 x LED Ring Pack
      • Light Sensor
      • Temp Sensor
      • Soil Moisture Sensor
      • Joystick
      • MQ2 Gas Sensor
      • Humiture Sensor
      • Extend Block
      • Flame Sensor
      • Magnetic Sensor
      • 5V Connection Cable-10cm × 5
      • 5V Connection Cable-20cm × 10
      Supplied software: mBlock
      Programming language: block-based language, Python
      BACK TO TOP
      /products/cyberpi-ai-iot-scientist-add-on-pack-5-pcs-limited
      Social Proof Apps
      403
      Access Denied
      You do not have permission to view this page
      Please contact ecommerce.hk@makeblock.com for assistance or refresh the page to retry. If you are using a VPN please disable it.
      IN,FR,DE,IT,AU,RU,NL,GB,TR,AE,KP,KR,SA,PL,TH,CO,MD,MX,PE,BR,ES,PH,ID
      OC,EU,AN,AF,SA
      none
      none
      none
      makeblock.myshopify.com
