Laserbox Rotary 40W (CO2)
    $3,999.00 $4,599.00
    fast-fulfilled by Amazon
    30-day money back
    lifetime support
      PAYMENTS payment icons
      • Shipping in 1-3 business days from local warehouses for US orders
      • 40W powerful CO2 laser cutting machine with speed up to 350mm/s
      • Built-in smart camera to bring your sketch to life
      • No internet required & 360° engraving for cylinders
      • The Laserbox Rotary only supports 110V power outlets
      Laserbox Rotary
      Best home laser cutter machine for small business.
      Best 3D laser cutter for small businesses / hobbyists / designers / DIY-Makers / professionals. Specially designed with education and creation in mind, the Laserbox reimagines and redefines laser performance. The Laserbox utilizes a high-resolution ultra-wide-angle camera together with an AI visual algorithm to bring your creations from idea into reality.
      Watch video
      Laserbox Rotary
      Best 3D laser cutter for small businesses/hobbyists/designers/DIY-Makers/professionals. Specially designed with education and creation in mind, the Laserbox reimagines and redefines laser performance. The Laserbox utilizes a high-resolution ultra-wide-angle camera together with an AI visual algorithm to bring your creations from idea into reality.
      Watch video
      We Bring Laser Cutting & Engraving to Easier Access
      Live Camera Preview
      Preview your design and visually position it on the material. The embedded 5MP ultra-wide-angle camera displays a visible working area in real time, ensuring accurate laser cutting or engraving.
      We Provide Wider Choices for Your Craft Ideas
      Engrave on Cylindrical Objects
      Rotary Engraving
      The rotary accessory attachment unlocks 360° engraving for cylinders from 3mm to 70mm in diameter. Customize a wide range of cylindrical materials with the rotary accessory attachment.
      Unlock Creativity with Your Kids
      Design with a Pen
      Directly draw your desired design on paper or directly on Laserbox materials, and get identically beautiful prints. xTool Laserbox recognizes a thick 3mm red color line for cutting and black for engraving automatically.
      Safe and Eco-friendly
      Job Pauses When Open The Lid
      Laserbox stops working at the same time you open the lid, completely safe to use even for children.
      Early-warning System
      Monitored in real time by collective high-performance sensors, Laserbox has multiple safety notifications, that immediately alert you to issues like overheating and water cooling
      Smart Smoke Purifier
      The smart smoke purifier automatically opens, and adjusts the volume according to the working status of Laserbox, which ensures eco-friendly ventilation. The filter for smoke purifier could be easily replaced.
      Safety Certification
      Buy with Confidence
      Twelve-month warranty
      Problem response within 24 hours
      No-questions-asked return policy
      See What People Are Saying
      Spec and Delivery
      Laser System
      Laser Power40W
      Laser SourceCO₂ Glass Laser Tube
       Lifespan6000~8000h
      Safety GuardClass I (FDA Certified)
      Materials Processing
      Max. Cutting Depth 0.59'' Basswood
      Max. Carving Speed350mm/s
      Carving Precision0.05mm
      Noise Rating≤70dB
      Rotary Device
      Rotary engraving diameter3-70mm(0.12''-2.76'')
      Rotatable engraving pattern typesImage / Line / Text
      Work Area
      Work Table Area19.69'' x 11.81''
      Max. Workpiece Height(with honeycomb tray)0.87''
      Max. Workpiece Height(without honeycomb tray)3.54''
      Work Table SurfaceBlack (Special surface finishing technique helps reduce burn marks or discoloration)
      AI Camera Information
      Focus Mode AI Visual AF/Material Recognition AF/Material Set-up AF
      CameraHigh-resolution Ultra-wide Camera
      Number of Pixels (Effective)5MP
      Visible Area19.29'' x 11.42''
      Image Resolution1000DPI
      PositioningAI Visual Positioning (Error range ≤ 5mm)
      Working Mode
      Cooling Closed-loop self-contained internal liquid cooling system
      Air AssistInternal air assist with no external compressor hookup required
      Connection / TransmissionWi-Fi, USB, Ethernet
      Appearance Overview
      Operation Panel Push Button + Circular LED Indicator Light
      Frame MaterialsV0 Flame Retardant ABS / PC
      Connecting InterfacesUSB cable/Ethernet cable/Power cable/Aviation Connector
      Outlet Diameter63.5mm
      Software Requirements
      Operating Systems Windows/macOS
      Control SoftwareLaserbox
      Design SoftwareAutoCAD, Solidworks, Inkscape, CorelDRAW, PowerPoint, Illustrator, Photoshop, Google AutoDraw, etc.
      Supported File TypeSVG, DXF, JPG, JPEG, PNG, BMP, TIF, CR2, etc.
      Software System Requirements
      Operating Systems 64-bit Windows 7 or later/macOS Mojave10.13 or later
      ProcessorCore i3 or AMD A6 2.4Ghz
      Memory Space4GB RAM
      Storage Space5GB
      Environmental Requirements
      Power 110VAC
      Work Consumption (without fan)350W
      Nonoperating Temperature0~45°C
      Relative Humidity5~90°C
      Operating Ambient Temperature0~35°C
      Size and Weight
      Product Weight 48kg
      Product Size (L x W x H)37.72'' x 20.79'' x 10.55''
      Supported Accessories
      Exhaust Fan
      Rotary Attachment
      Unboxing and Reviews
      xTool Laserbox — Bring Sketch to Life
      Adam tries a 40w CO2 Laser-Cutter! Makeblock Laserbox REVIEW
      You may be wondering
      BACK TO TOP
      /products/laserbox-rotary-40w-co2
      Social Proof Apps
      403
      Access Denied
      You do not have permission to view this page
      Please contact ecommerce.hk@makeblock.com for assistance or refresh the page to retry. If you are using a VPN please disable it.
      none
      none
      none
      none
      none
      makeblock.myshopify.com
