You have no items in your shopping cart.
Notification of Shipping
We are so sorry that due to the COVID-19 crisis, the delivery time of your packages will be longer than we promised as usual. Currently, we cannot provide the excat delivery time for you. If you cannot accept it, please directly write to us and request to cancel your order. Thanks for your understanding.
Product Description
Makeblock is an open source construction platform that turns your ideas into reality. No matter what your idea is and however impossible it looks like, Makeblock will make it possible by providing various mechanical parts and electronic modules, such as beams, plates, connectors, motors, brackets, sensors,drivers, controllers, and etc. Characterized by "Open, Fun, and Creative" thru mDrawbot, mBot, mElephant 3D Printer, XY Plotter, Starter Robot Kit and Ultimate Robot Kit, Makeblock has become one of the best intelligent hardware companies that strive to make differences.
What is 180 Optical Encoder Motor?
180 optical encoder motor is equipped with optical encoder which enables motor to control in high-accuracy. And the unique structure makes this motor compliable with various parts. Meanwhile, due to the special materials, it produces lower noise while running and promises large output torque.
Specification:
- Reduction Ratio: 39.6
- Rated Voltage: 7.4V
- No Load Current: 240mA
- Load Current: ≤750mA
- NO Load Speed: 350RPM±5%
- Rated Load Speed (RPM): 178±10%
- Rated Speed: 14000RPM±5%
- Rated Load Torque: 800g.cm
- Break-out Torque: 5kg.cm
- Output Shaft: 9mm
- Power: 3.7W
- Encoder accuracy: 360
