$19.99
Makeblock is an open source construction platform that turns your ideas into reality. No matter what your idea is and however impossible it looks like, makeblock will make it possible...
Availability: 9 In Stock
Makeblock is an open source construction platform that turns your ideas into reality. No matter what your idea is and however impossible it looks like, makeblock will make it possible by providing various mechanical parts and electronic modules, such as beams, plates, connectors, motors, brackets, sensors, drivers, controllers, and etc. Characterized by "Open, Fun, and Creative" thru mDrawbot, mBot, mElephant 3D Printer, XY Plotter, Starter Robot Kit and Ultimate Robot Kit, makeblock has become one of the best intelligent hardware companies that strive to make differences.
Description
This 2.4G Wireless Serial is designed for mBots to be used in classroom or workshop when many people use wireless communication simultaneously. It uses the same the technology as wireless mouse. With the feature of no pairing needed and no drivers needed, there is no signal interference when many modules work simultaneously. With two parts included: a dongle to plug on your computer; a module to plug on the mCore, you can easily establish a wireless connection between the software mBlock and mBot.
Specifications
Default Baud rate:115200
Communication distance: about 10 meters
Power supply: 5V DC
Dimension: 30mm*20mm*14mm
Packing List
2.4G Wireless Serial Module × 1
2.4G Wireless Serial USB × 1
Instructions
https://www.youtube.com/watch?v=kiO8VYpIGsw
