You have no items in your shopping cart.
$9.99
Suitable for the mBot: mBot Li-polymer battery is suitable for the mBot(blue & pink) of Makeblock. It takes only 1 hour to fully charge the battery and the battery can...
Availability:
Out Of Stock
mBot Li-polymer battery is suitable for the mBot(blue & pink) of Makeblock. It takes only 1 hour to fully charge the battery and the battery can last up to 2-5 hours in the offline mode.
Charging method: Charging via mbot's USB cable. The battery does not include a charger.
Specifications:
Protective cases: prevent overcharge/overdischarge/short circuit/overcurrent
Type: Li-polymer battery/Rechargeable battery
Charging method: Connect to mCore via USB
Capacity: 1800mAh
Nominal voltage: 3.7V
Charge cutoff voltage: 4.2V
Discharge cutoff voltage: 2.75V
Charging current: ≤1.0C
Discharge current: ≤1.0C
Weight: 33g Dimension: 1 * 3.5 * 5cm
