$49.99
Notification of ShippingWe are so sorry that due to the COVID-19 crisis, the delivery time of your packages will be longer than we promised as usual. Currently, we cannot provide the...
Availability: 30 In Stock
We are so sorry that due to the COVID-19 crisis, the delivery time of your packages will be longer than we promised as usual. Currently, we cannot provide the excat delivery time for you. If you cannot accept it, please directly write to us and request to cancel your order. Thanks for your understanding.
What is Perception Gizmos Add-on Pack?
Makeblock Perception Gizmos Add-on Pack is a 7-in-1 pack for mBot & mBot Ranger. The perception gizmos add-on pack for mBot and mBot Ranger is a brand new add-on pack. It contains five add-on cases for mBot and two for mBot Ranger. It has enriched the cases for motion control and appearance relative to mBot and mBot Ranger. Besides, you can assemble it into more forms on your own idea, and explore more possibilities.
Product parts
1× Temperature and Humidity Sensor 1× Sound Sensor
1× Potentiometer 1× LED Matrix 8×16
1× 130 Motor Pack 4× RJ25 Cable
2× Beam 0824-096 2× Beam 0808-072
2× Bracket 3×3 2× Plate 45°
1× Wrench 5mm&7mm 4× Brass Stud M4×25mm
16× Screw M4×8mm 20× Screw M4×14mm
4× Screw M4×22mm 20× Nut M4
10× Plastic Spacer 4×7×3mm
Five cases for mBot
1) mBot add-on case 1: Range finder
Range finder can measure the range by handheld device. Off-line operation is available.
2) mBot add-on case 2: Sound control lamp
The lamp would be turned on in dark area when sound reach at certain value.
3) mBot add-on case 3: Weather station
It can measure temperature and humidity and show the value on the LED screen.
4) mBot add-on case 4: Knob Robot
It is a robot that can play number guessing game.
5) mBot add-on case 5: Energy-saving fan
The fan would be turned on when you get close to it, and it would be turned off when you leave it.
Two cases for mBot Ranger
1) mBot Ranger add-on case 1: Roly-poly
The robot can return to vertical state after shaking. And it can do specific action and expression by programming.
2) mBot Ranger add-on case 2: Music Box
The music box would be switched on by controlling lights. When the music starts, the doll beginning to spin, and the LED lighting up.
