Makeblock mBot & mBot Ranger Add-on Pack, 8-in-1 Variety Gizmos Add-on Pack, 8 shapes - MAKEBLOCK
    $58.78
    Shipping calculated at checkout.
      DESCRIPTION
      Notification of Shipping
      We are so sorry that due to the COVID-19 crisis, the delivery time of your packages will be longer than we promised as usual. Currently, we cannot provide the excat delivery time for you. If you cannot accept it, please directly write to us and request to cancel your order. Thanks for your understanding.
      What is Variety Gizmos Add-on Pack?
      Makeblock Variety Gizmos Add-on Pack is a 8-in-1 pack based on mBot & mBot Ranger. The variety gizmos add-on pack for mBot and mBot Ranger is a brand new add-on pack. It contains six add-on cases for mBot and two for mBot Ranger. It has enriched the cases for motion control and appearance relative to mBot and mBot Ranger. Besides, you can assemble it into more forms on your own idea, and explore more possibilities.
      Product parts
      1× RJ25 Adapter Module 1× RGB LED Module
      1× Segment Serial Display 2× Micro Switch B
      1× 9g Micro Servo Pack 4× RJ25 Cable
      2× Cuttable Linkage 2× Plate I1
      2× Plate 45° 4× Brass Stud M4×25mm
      2× Bracket 3×3 2× Bracket 120° 3×3
      16× Screw M4×8mm 20× Screw M4×14mm
      4× Screw M4×22mm 20× M4 Nut
      10× Plastic Spacer 4×7×3mm 1× Wrench 5mm&7mm
      Five cases for mBot
      1) mBot add-on case 1: Range finder
      Range finder can measure the range by handheld device. Off-line operation is available.
      2) mBot add-on case 2: Sound control lamp
      The lamp would be turned on in dark area when sound reach at certain value.
      3) mBot add-on case 3: Weather station
      It can measure temperature and humidity and show the value on the LED screen.
      4) mBot add-on case 4: Knob Robot
      It is a robot that can play number guessing game.
      5) mBot add-on case 5: Energy-saving fan
      The fan would be turned on when you get close to it, and it would be turned off when you leave it.
      Two cases for mBot Ranger
      1) mBot Ranger add-on case 1: Roly-poly
      The robot can return to vertical state after shaking. And it can do specific action and expression by programming.
      2) mBot Ranger add-on case 2: Music Box
      The music box would be switched on by controlling lights. When the music starts, the doll beginning to spin, and the LED lighting up.
      BACK TO TOP
      Social Proof Apps
