Makeblock MegaPi Stepper Motor Driver
2 sold in last 8 hours
$9.99
Description
This module is designed to drive stepper motors. It uses the DRV8825 chip and has a maximum driving current of 2.5 A. DRV8825 is a complete micro-stepping motor driver, equipped with a built-in converter for easy operation. It is designed to drive bipolar stepper motors that work in full, 1/2, 1/4, 1/8/ 1/16, or 1/32 step modes. An on-board potentiometer is provided, which allows you to change the current of a motor easily.
Features
  • Compatible with 4-wire bipolar stepper motors
  • Potentiometer, used to control the current of a stepper motor
  • On-board heat sink, facilitating heat dissipation
  • Capable of driving one-step stepper motors (green interface) • Color-coded male and female pins, ensuring correct connection • Small size, facilitating connection
Specifications
  • Motor driver: DRV8825
  • Output current:1.75 A (with proper heat sinking at 24 V and 25°C)
  • Max current: 2.5 A (pay attention to heat dissipation)
  • Driver voltage: 8.2 V–45 V Note: The maximum power supply voltage of MegaPi is 12 V.
  • Logic voltage: 5 V
  • Dimensions: 1.5 cm x 2.0 cm
$9.99
customers are viewing this product
Tags: /
[time] minutes ago, from [location]
Customer Reviews
No reviews yet
0%
(0)
0%
(0)
0%
(0)
0%
(0)
0%
(0)
You have successfully subscribed!
This email has been registered
Newsletter
ico-collapse
ic-cross-line-top
Top
ic-expand
ic-cross-line-top
Social Proof Apps
