You have no items in your shopping cart.
Main Features:
● Makeblock socket cap screw will be replaced by button head socket cap screw gradually, and the tool HEX screwdriver 3mm will be replaced by HEX screwdriver 2.5mm.
● Button head socket cap screw is a new kind of socket cap screw, it has smaller head that can solve most problem of interfere with other components.
● Thread drive pack V2.0 is the improvement version of thread drive pack V1.0. It can be used to build thread drive system.
● DC motors are the most commonly used motors in Makeblock platform. They may be easy to connect to Makeblock structural components by Makeblock DC motor-25 brackets.
●Test condition: DC 6.0Vrated voltage. 25 plus or minus 3 Degree Celsius ambient temperature. 60 plus or minus 5 percent ambient relative.
●No-load characteristic: 1:34 reduction ratio. No load current: Less than or equal to 200mA. No load speed: 185 plus or minus 10 percent rpm.
●Load characteristic: Rated torque: 1.5kg/cm. Rated current: Less than or equal to 650mA. Rated speed: 135 plus or minus 10 percent rpm. Stall torque: 4.5kg/cm. Stall current: Greater than or equal to 2.0A.
● Direction of rotation: CCW.
● Thrust play of shaft: 0.05 - 0.5mm.
● Radial play of shaft: Less than or equal to 0.02mm.
Part List
2 x Beam (0824-80) |
2 x Beam (0808-192) |
1 x DC Motor-25(6V/185RPM) |
1 x DC Motor-25 (Bracket) |
1 x Universal Joint (4x4mm) |
1 x Threaded Rod (M4x192mm) |
1 x Threaded Rod (M4x288mm) |
2 x Linear Motion Shaft (D4x288mm) |
1 x Thread Drive Beam (M4x80) |
10 x Socket Cap Screw (M4x14) |
4 x Countersunk Screw (M3x8) |
2 x Headless Set Screw (M3x5) |
