Makeblock Robotic Arm Add-on Pack for Starter Robot Kit-Blue - MAKEBLOCK
    $89.99
    Shipping calculated at checkout.
      DESCRIPTION
      Product Description
      Makeblock is an open source construction platform that turns your ideas into reality, no matter what your idea is and however impossible it looks like. Makeblock will make it possible by providing various mechanical parts, electronic modules and software. Makeblock has become one of the best intelligent hardware companies that strive to make differences.
      • Expanded upon Makeblock Starter Robot Kit to build a Robotic Arm Tank or Robotic Arm Car
      • All parts of the robotic arm are included
      • Largest open size of robot gripper is 76mm
      • Motor for the gripper will stop when it is fully opened and closed
      Transform Your Starter
      Robot Arm Add-on Pack serves to transform your Starter Robot Kit to a robotic-arm tank. It contains all parts you need for building a robotic arms: DC Motor-37, Robot Gripper, beams, timing pulleys, etc.
      Devoted to Bring Fun
      Composing of easy-to-assemble mechanical parts, color-labelled electronic modules, and a nimble gripper, controlled by IR remoter controller, this pack aims to bring more fun: pick up a bottle of water and get it delivered under your command.
      Large Open-Width Gripper
      The gripper included in this pack is capable of opening an impressive 3" (67mm) wide. It enables you to grip items of various sizes according to your needs.
      Self-Protection Design
      The inner N20 screw motor of the gripper included in this pack will automatically stop running when the gripper is fully open or closed. This protects the screw motor from short-circuits and over-current, ensuring long-time use of the gripper.
      Manual
      More information please go here: https://github.com/Makeblock-official/Robotic-Arm-Add-On-Pack-For-Starter-Robot-Kit.
      Notification
      The Socket Cap Screw in this pack is button head socket cap screw which shall be used together with 2.5mm HEX Screwdriver (also included in this pack). Button Head Socket Cap Screw, as a new type socket cap screw, has smaller head that can solve most interference problems between components.
      BACK TO TOP
      Social Proof Apps
