Product Introduction
STEAM Education Advanced Solution provides resources that help middle schools or above set up their STEAM labs and organize robotics competitions. It includes 45 boxes of components, 12 backup storage trays and 10 packs of runners and clips compatible with storage shelves. The solution can work with MakerSpace series based middle school courses, making it a perfect setup for classroom teaching (for a class size of 2-8 students) and maker education activities (for 8 - 16 students involved). Moreover, the solution can equip one middle- or high-level MakeX team with supplies necessary for the Challenge or Premier competition, and can be used in conjunction with other MakerSpace kits to increase the class and team size.
Part List (Qty. x Part Name)
MakerSpace Kits2.0-mBot Modules | |||
4 x Mainboard mCore | 4 x Chassis | 4 x Bluetooth Module | |
MakerSpace Kits2.0-Electronic Modules 1 | |||
4 x Me Auriga | 2 x MegaPi Acrylic Bracket | 2 x MegaPi Pro 4DC Motor Driver | 2 x MegaPi Pro |
2 x Power Cord | 2 x MegaPi Pro Shield for RJ25 | 2 x Bluetooth Module | |
MakerSpace Kits2.0-Electronic Modules 2 | |||
2 x Sound Sensor | 2 x Gas Detection Module | 4 x Line Follower | 2 x PIR Motion Sensor |
4 x Light Sensor | 8 x RGB LED | 2 x Flame Sensor | 4 x Color Sensor |
4 x RGB Line Follower | |||
MakerSpace Kits2.0-Electronic Modules 3 | |||
4 x Micro SD Card | 4 x Ultrasonic Sensor | 4 x 4 Button | 4 x 7-segment Display |
2 x Temperature and Humidity Sensor | 2 x Compass | 2 x 3-Axis Accelerometer and Gyro Sensor | 2 x Infrared Receiver decode |
4 x Audio Player | 4 x Touch Sensor | 4 x Potentiometer | |
MakerSpace Kits2.0-Electronic Modules 4 | |||
2 x Temperature Sensor | 4 x LED Matrix | 2 x Me TFT LCD Screen-2.4 Inch | 2 x Slide Potentiometer |
4 x LED RGB Strip(0.5M) | 4 x RJ25 Adapter | 4 x LED RGB Strip(1M) | |
MakerSpace Kits2.0-Electronic Modules 5 | |||
8 x Micro Switch B | 4 x Bluetooth Controller | 4 x IR Controller | 4 x Bluetooth Dongle |
4 x Joystick | |||
MakerSpace Kits2.0-Electronic Modules 6 | |||
2 x AC to DC 12V/3A Wall Adapter Power Supply For Arduino / Meduino | 4 x Adapter For 18650 Lithium Battery | 6 x USB type B Cable | 16 x RJ25 Cable-50cm |
8 x RJ25 to Dupont Wire | 6 x Micro USB Cable | 16 x RJ25 Cable-20cm | |
MakerSpace Kits2.0-Beam0824 Structural Parts*2 | |||
16 x Slide Beam0824-016 | 16 x Slide Beam0824-032 | 16 x Slide Beamo824-048 | 16 x Slide Beam0824-064 |
16 x Slide Beam0824-080 | 16 x Slide Beam0824-096 | 16 x Slide Beam0824-112 | 8 x Slide Beam0824-128 |
8 x Slide Beam0824-144 | 8 x Slide Beam0824-160 | 8 x Slide Beam0824-176 | 8 x Slide Beam0824-192 |
8 x Slide Beam0824-224 | 8 x Slide Beam0824-256 | 8 x Slide Beam0824-320 | |
MakerSpace Kits2.0-Beam0808 Structural Parts | |||
16 x Beam0808-024 | 16 x Beam0808-40A | 16 x Beam0808-40B | 16 x Beam0808-056 |
16 x Beam0808-072 | 16 x Beam0808-080 | 16 x Beam0808-088 | 16 x Beam0808-104 |
16 x Beam0808-120 | 16 x Beam0808-136 | 16 x Beam0808-152 | 16 x Beam0808-168 |
16 x Beam0808-184 | 16 x Beam0808-312 | ||
MakerSpace Kits2.0-Beam0412 Structural Parts | |||
16 x Beam0412-036 | 16 x Beam0412-044 | 16 x Beam0412-060 | 16 x Beam0412-076 |
16 x Beam0412-092 | 16 x Beam0412-108 | 16 x Beam0412-124 | 16 x Beam0412-140 |
16 x Beam0412-156 | 16 x Beam0412-172 | 16 x Beam0412-188 | 16 x Beam0412-188-L2-R1 |
16 x Beam0412-204 | 16 x Beam0412-220 | 16 x Beam0412-220-L5 | 16 x Beam0412-236 |
MakerSpace Kits2.0-Square Beam Structural Parts | |||
16 x Square Beam0808-016 | 16 x Square Beamo808-032 | 16 x Square Beam0808-040 | 16 x Square Beam0808-056 |
16 x Square Beam0808-072 | 16 x Square Beam0808-088 | 16 x Square Beam0808-104 | 16 x Square Beam0808-120 |
16 x Square Beam0808-136 | 16 x Square Beam0808-152 | 16 x Square Beam0808-168 | 16 x Square Beam0808-184 |
MakerSpace Kits2.0-Slide Beam2424 Structural Parts*2 | |||
8 x Slide Beam2424-072 | 8 x Slide Beam2424-104 | 8 x Slide Beam2424-136 | 8 x Slide Beam2424-168 |
8 x Slide Beam2424-184 | 8 x Slide Beam2424-248 | 8 x Slide Beam2424-312 | |
MakerSpace Kits2.0-Connecting Fittings | |||
24 x Brakcet 3*3 | 16 x Bracket 3*6 | 16 x Plate 3*6 | 16 x Plate 7*9-B |
16 x Plate l1 | 16 x Plate O1 | 16 x Plate A | 16 x Triangle Plate 6*8 |
16 x Plate45° | 16 x Bracket L1 | 16 x Bracket U1 | 16 x Bracket U-B |
8 x Disc D72 | 8 x Bracket P1 | 8 x Bracket P3 | 48 x Cuttable Linkage |
24 x Cuttable Linkage 3 Hole | 8 x Stiffener 1616-008-M4 | 8 x Plate0324-040 | 8 x Plate0324-056 |
16 x Plate0324-072 | 16 x Plate0324-088 | 16 x Plate0324-184 | 24 x Plate 3*5*120 |
24 x Bracket 3*3*120 | 8 x Bracket U-C | ||
MakerSpace Kits2.0-Large Parts | |||
4 x Lean Beam-424 | 4 x Lean Beam-504 | 4 x Slide Beam-424 | 4 x Slider 496(Blue) |
4 x Beam0808-504(Blue) | 6 x Slide Beam0824-496 | 4 x Shaft D8*512mm-H | 6 x Shaft D8*496mm-H |
2 x 360*256mm Aluminium Sheet | 2 x Base Plate- S(Blue) | ||
MakerSpace Kits2.0-Hardwares and Tools 1*2 | |||
400 x Socket Cap Screw M4*8-Button Head | 100 x Socket Cap Screw M4*40-Button Head | 100 x Socket Cap Screw M4*35-Button Head | 100 x Socket Cap Screw M4*30-Button Head |
100 x Socket Cap Screw M4*22-Button Head | 200 x Socket Cap Screw M4*16-Button Head | 400 x Socket Cap Screw M4*14-Button Head | 60 x Cross Recess Screw M3*8-Countersunk Head |
100 x Plastic Spacer 4*8*1 | 100 x Plastic Spacer 4*7*3 | 200 x Plastic Spacer 4*7*2 | 40 x Plastic Spacer 4*7*10 |
120 x Plastic Rivet R4120(White) | 120 x Plastic Rivet R4100(White) | 120 x Plastic Rivet R4060(Black) | 80 x Tapping Screw with Washer M2.2*9.5-Round Head |
20 x Nylon Stud M4*30 | 10 x Velcro sticker pad | 40 x Nylon Cable Ties1.9*100 | 20 x Hex Nut M8 |
400 x Hex Nut M4 | 200 x Hex Nut M3 | 200 x Hex Lock Nut M4 | 100 x Cross Recess Screw M3*25-Button Head |
100 x Cross Recess Screw M3*16-Button Head | 4 x Cross &2.5mm HEX Screwdriver V2.0 | 40 x Brass Stud M4*8+6 | 24 x Brass Stud M4*32 |
40 x Brass Stud M4*16 | 6 x Wrench M5+M7 | 8 x HEX Allen Key 1.5mm | 8 x HEX Allen Key 2.5mm |
100 x Headless Screw M3*5 | 2 x 2 Inch G-clamp | ||
MakerSpace Kits2.0-Hardwares and Tools 2*2 | |||
100 x Headless Screw M3*8 | 200 x Combination Screw M4*8 | 200 x Combination Screw M4*10 | 200 x Combination Screw M4*14 |
400 x Combination Screw M4*16 | 400 x Combination Screw M4*20 | 200 x Combination Screw M4*30 | 400 x Combination Screw M4*35 |
200 x Combination Screw M4*40 | 200 x Hex Lock Nut M3 | 4 x Small Four-way socket wrench | 4 x Rapid Steel Allen Driver 1.5mm(Black) |
4 x Rapid Steel Allen Driver 3mm(Black) | 600 x Hex Nut M4 | 200 x Hex Lock Nut M4 | 8 x Brass Stud M4*25+6 (Pack of 4) |
8 x Brass Stud M4*16+6 (Pack of 4) | |||
MakerSpace Kits2.0-Basic Drive Parts 1 | |||
8 x Timing Belt 140T(112MXL) | 8 x Timing Belt 300T(240MXL) | 6 x Timing Belt-Open end(5m) | 8 x Belt Connector-B |
8 x Belt Connector | 8 x Timing Pulley Slice 90T-B | 8 x Timing Pulley Slice 62T-B | 8 x Plastic Timing Pulley 18T |
4 x Timing Pulley 90T | 4 x Timing Pulley 62T | 4 x Fully Threaded Rod M4*192 | 4 x Fully Threaded Rod M4*288 |
4 x Fully Threaded Rod M4*248 | 8 x Thread Drive Beam M4*40 | 8 x Sliding Block A1 | 32 x Aluminum Sleeve4*6*4 |
32 x Aluminum Sleeve 4*6*6 | 32 x Roller(With Bearing) | 16 x Nylon Wheel( No Bearing) | 8 x V-slot Bearing 4*136 |
4 x Slider 256 | |||
MakerSpace Kits2.0-Basic Drive Parts 2*2 | |||
8 x Gear 16T | 8 x Gear 48T | 8 x Gear 80T | 32 x Double gear Rack |
32 x Plastic Gear 8T | 32 x Plastic Gear 56T | 64 x Plastic Gear 72T | |
MakerSpace Kits2.0-Shaft Type Drive Parts | |||
20 x D Shaft 4*56 | 8 x D Shaft 4*128 | 12 x D Shaft 4*160 | 8 x Shaft 8*96-H |
8 x Shaft 8*128-H | 8 x Shaft 8*312-H | 24 x Shaft 4*88 | 8 x Shaft 4*240 |
8 x Shaft 4*288 | 8 x Linear Box Slider D8 | 100 x Flange Bearing 4*8*3 | 20 x Bearing 4*8*3 |
20 x Bearing 8*16*5 | 16 x Threaded shaft 4*39 | 80 x Shaft Collar 4mm | 40 x Shaft Collar 8mm |
8 x Universal Joint 4*4 | 20 x Bearing F688ZZ | 30 x Shaft Connector 4mm | 16 x Flexible Coupling 4*4 |
8 x Shaft Clamping Hub 8mm | 16 x 8mm Bearing Bracket A | 30 x Shaft Connector 4mm V3.0 | |
MakerSpace Kits2.0-Motion Parts 1*2 | |||
32 x Plastic Timing Pulley 62T | 32 x Plastic Timing Pulley 90T | 16 x Plastic Timing Pulley 62T For Motor | 32 x Plastic Timing Pulley 90T For Motor |
32 x Tyre 68.5*22mm | 16 x Slick Tire | 16 x Mini Caster Wheel | |
MakerSpace Kits2.0-Motion Parts2*2 | |||
400 x Track | 400 x Track Axle | 8 x 58mm Omni Wheel Coupling Pack | 8 x 1 Inch Nylon Pulley |
16 x 58mm Omni Wheel | |||
MakerSpace Kits2.0-Servos | |||
8 x 9g Micro Servo Robot Pack | 4 x RJ25 Adapter | 8 x Smart Servo MS-12A | 8 x Rudder Bracket |
8 x Terminal Wire-20cm | 8 x Terminal Wire 60cm | 8 x Mounting Bracket | 8 x Virtual Axis |
4 x MEDS150 Servo Motor | 8 x Color Number Sticker | ||
MakerSpace Kits2.0-Motor Modules 1 | |||
8 x Geared Motor DC6V/312RPM | 4 x Me 130 Motor Pack-5V/10000RPM | ||
MakerSpace Kits2.0-Motor Modules 2*2 | |||
8 x DC Motor-37 12V/50RPM | 8 x DC Motor-37 12V/200RPM | 8 x DC Motor-25 9V/185RPM | 8 x Optical Encoder Motor-25 9V/185RPM |
MakerSpace Kits2.0-Motor Modules 3 | |||
16 x DC Motor-25 Bracket | 16 x DC Motor-37 Bracket | 8 x Dual Motor Driver | 32 x PH2.0 Motor Cable |
8 x 180 Optical Encoder Motor | 8 x Dual Motor Driver | 4 x Encoder Motor Driver | 8 x High-Power Encoder /DC Motor Driver |
8 x 2. 54mm 6P Encoder Motor Cable | 8 x MegaPi Pro Encoder/DC Motor Driver | 8 x 25 Encoder Motor Cable | |
MakerSpace Kits2.0-Motor Modules 4 | |||
2 x Air Pump Motor-DC 12V/370-02PM | 2 x Solenoid Valves DC 12V/0520E | 2 x Water Pump Motor-DC 12V370-04PM | 2 x Silicone Air Tube 0507 |
2 x Vacuum Suction Head M4 | 2 x Silicone Air Tube 0305 | 2 x Vacuum Suction Cup-SP-30 | 2 x Mini Gripper |
4 x Robot Gripper-Black | |||
MakerSpace Kits2.0-Motor Modules 5 | |||
4 x 42BYG Stepper Motor Bracket-B | 4 x 42BYG Stepper Motor | 4 x Me Stepper Motor Driver | 2 x Brushless Motor |
4 x MegaPi Pro ESC Driver V1.0 | 4 x Friction Wheel D45*19.5 | 4 x Friction Wheel Ring D28*7 | 4 x Megapi Stepper Motor Driver |
MakerSpace Kits2.0-Motor Modules 6 | |||
8 x DC Planet Geared Motor 36mm | 8 x 36mm DC Motor Bracket | ||
MakerSpace Kits2.0-Motion Parts 3 | |||
8 x 100mm Omni Wheel | 8 x 100mm Omni Wheel Coupling | 40 x Cuphead Screw M5*40 | 40 x Lock Nut M5 |
MakerSpace Kits2.0-Motion Parts 4 | |||
4 x 100mm Left Mecanum Wheel with 4mm Shaft | 4 x 100mm Right Mecanum wheel with 4mm Shaft | 8 x Mecanum Wheel Pack | |
MakerSpace Kits2.0-Chain Transmission Parts | |||
4 x 04C 20T Sprockets | 2 x 04C 14T Double Sprockets | 4 x 04C 10T Sprockets | 4 x 04C Roller Chain-1.5 |
2 x 04 Chain Rivet Extractor | 2 x 04C Half Chain Unit | 2 x 04C Chain Unit | 4 x 04C One-hole Bending Chain |
16 x Headless Screw M3*5 | 16 x Headless Screw M5*5 | 8 x Shaft 8*96-H | 8 x Shaft Collar 8mm |
4 x Bracket U-B | |||
MakerSpace Kits2.0-MakeX Electronic Modules | |||
8 x Dual RGB Color Sensor | 8 x Ranging Sensor | 2 x Power Expansion Board | 16 x PH2. 0 Motor Cable |
2 x Me Power Management Module | 2 x Main Board NovaPi | 8 x Smart Moter Cable-60CM | 12 x 5V General Cable-20cm |
2 x Low Voltage Buzzer Alarm | 4 x Bluetooth Module | 2 x XT60 XT30/DC One with Three Power Cords | 12 x 5V General Cable-60cm |
MakerSpace Kits2.0-MakeX Batteries | |||
4 x Lithium Battery | 4 x 18650 Lithium Battery Pack | 2 x FB4300HP-3SLI-PO Battery | |
MakerSpace Kits2.0-MakeX Motor Modules | |||
1 x Skyr B6AC V2 | 4 x x180 Smart Encoder Motor | 2 x xNovaPi Case | 4 x 36 Encoder Motor-Brushless |
MakerSpace Kits2.0-Lean Beam 1 | |||
4 x Lean Beam-072 | 4 x Lean Beam-136 | 4 x Lean Beam-248 | 8 x Lean Beam-312 |
MakerSpace Kits2.0-Lean Beam 2 | |||
8 x Parallel Connector | 16 x Lean Beam Adapter A | 16 x Lean Beam Adapter B | 40 x External Connector |
16 x Cross Connector | 8 x Extension Connector | 16 x 90 Reinforce Connector | 4 x 45° Connector A |
4 x 45° Connector B | 30 x Socket Cap Screw M6*12-Round Head | 30 x Socket Cap Screw M6*16-Round Head | 20 x Socket Cap Screw M6*20-Round Head |
80 x Hex Nut M6 | 2 x Wrench M6 | ||
MakerSpace Kits2.0-Pneumatic Parts | |||
2 x Regulator GR20006F1 | 2 x Pressure Relief Valve | 4 x Solenoid Valve 4V110M5FI | 4 x Plug 3.96-2P |
2 x Cylinder Ml10X60CA | 2 x Cylinder MI10X150CA | 4 x Bottle Cap | 2 x φ8-φ6 Reducing Straight Connector |
4 x Tube Connector PE6 | 2 x φ6 Cross Four-Way Connector PZ6 | 4 x Hand Control Valve 6-6 | 2 x Tube Connector PCFT6-02 |
4 x Tube Connector PC6-01 | 8 x Speed Valve PSL6M5A | 30 x Tube Connector PC6M5 | 10 x Universal Copper Silencer |
4 x φ6 Pneumatic Tube -Blue | 2 x Sealing Tape | 4 x Solenoid Valve Bracket(6061-T6) | 4 x φ10 Cylinder Bracket(6061-T6) |
4 x Rod End Joint M4 | 16 x Lock Nut M3 | 16 x Socket Cap Screw m3*25-Button Head | |
Gratnells Shallow Tray, CyanBlue (Pack of 4)*3 | |||
12 x Gratnells Shallow Tray, CyanBlue | |||
Lid for Standard Trays, Translucent (Pack of 4)*3 | |||
12 X Lid for Standard Trays, Translucent | |||
Gratnells Tray Runners with Clips for Trays (Pack of 6 pairs)*10 | |||
60 x tray clips | 60 x runners |
