Skip to content
Makeblock STEAM Education Intermediate Solution Kit
Sold out
$20,099.00
Product Description
STEAM Education Intermediate Solution provides resources that help middle schools set up their STEAM labs and organize robotics competitions. It includes 34 boxes of components, 8 backup storage trays and 7 packs of runners and clips compatible with storage shelves. The solution can work with MakerSpace series based middle school courses, making it a perfect setup for classroom teaching (for a class size of 2-8 students) and maker education activities (for 8 - 16 students involved). Moreover, the solution can equip 2 MakeX teams with supplies necessary for the Challenge competition, and can be used in conjunction with other MakerSpace kits  to increase the class and team size.
Part List  (Qty. x Part Name)
MakerSpace Kits2.0-mBot Modules
4 x Mainboard mCore 4 x Chassis 4 x Bluetooth Module
MakerSpace Kits2.0-Electronic Modules 1
4 x Me Auriga 2 x MegaPi Acrylic Bracket 2 x MegaPi Pro 4DC Motor Driver 2 x MegaPi Pro
2 x Power Cord 2 x MegaPi Pro Shield for RJ25 2 x Bluetooth Module
MakerSpace Kits2.0-Electronic Modules 2
2 x Sound Sensor 2 x Gas Detection Module 4 x Line Follower 2 x PIR Motion Sensor
4 x Light Sensor 8 x RGB LED 2 x Flame Sensor 4 x Color Sensor
4 x RGB Line Follower
MakerSpace Kits2.0-Electronic Modules 3
4 x Micro SD Card 4 x Ultrasonic Sensor 4 x 4 Button 4 x 7-segment Display
2 x Temperature and Humidity Sensor 2 x Compass 2 x 3-Axis Accelerometer and Gyro Sensor 2 x Infrared Receiver decode
4 x Audio Player 4 x Touch Sensor 4 x Potentiometer
MakerSpace Kits2.0-Electronic Modules 4
2 x Temperature Sensor 4 x LED Matrix 2 x Me TFT LCD Screen-2.4 Inch 2 x Slide Potentiometer
4 x LED RGB Strip(0.5M) 4 x RJ25 Adapter 4 x LED RGB Strip(1M)
MakerSpace Kits2.0-Electronic Modules 5
8 x Micro Switch B 4 x Bluetooth Controller 4 x IR Controller 4 x Bluetooth Dongle
4 x Joystick
MakerSpace Kits2.0-Electronic Modules 6
2 x AC to DC 12V/3A Wall Adapter Power Supply For Arduino / Meduino 4 x Adapter For 18650 Lithium Battery 6 x USB type B Cable 16 x RJ25 Cable-50cm
8 x RJ25 to Dupont Wire 6 x Micro USB Cable 16 x RJ25 Cable-20cm
MakerSpace Kits2.0-Beam0824 Structural Parts
8 x Slide Beam0824-016 8 x Slide Beam0824-032 8 x Slide Beamo824-048 8 x Slide Beam0824-064
8 x Slide Beam0824-080 8 x Slide Beam0824-096 8 x Slide Beam0824-112 4 x Slide Beam0824-128
4 x Slide Beam0824-144 4 x Slide Beam0824-160 4 x Slide Beam0824-176 4 x Slide Beam0824-192
4 x Slide Beam0824-224 4 x Slide Beam0824-256 4 x Slide Beam0824-320
MakerSpace Kits2.0-Beam0808 Structural Parts
16 x Beam0808-024 16 x Beam0808-40A 16 x Beam0808-40B 16 x Beam0808-056
16 x Beam0808-072 16 x Beam0808-080 16 x Beam0808-088 16 x Beam0808-104
16 x Beam0808-120 16 x Beam0808-136 16 x Beam0808-152 16 x Beam0808-168
16 x Beam0808-184 16 x Beam0808-312
MakerSpace Kits2.0-Beam0412 Structural Parts
16 x Beam0412-036 16 x Beam0412-044 16 x Beam0412-060 16 x Beam0412-076
16 x Beam0412-092 16 x Beam0412-108 16 x Beam0412-124 16 x Beam0412-140
16 x Beam0412-156 16 x Beam0412-172 16 x Beam0412-188 16 x Beam0412-188-L2-R1
16 x Beam0412-204 16 x Beam0412-220 16 x Beam0412-220-L5 16 x Beam0412-236
MakerSpace Kits2.0-Square Beam Structural Parts
16 x Square Beam0808-016 16 x Square Beamo808-032 16 x Square Beam0808-040 16 x Square Beam0808-056
16 x Square Beam0808-072 16 x Square Beam0808-088 16 x Square Beam0808-104 16 x Square Beam0808-120
16 x Square Beam0808-136 16 x Square Beam0808-152 16 x Square Beam0808-168 16 x Square Beam0808-184
MakerSpace Kits2.0-Slide Beam2424 Structural Parts
4 x Slide Beam2424-072 4 x Slide Beam2424-104 4 x Slide Beam2424-136 4 x Slide Beam2424-168
4 x Slide Beam2424-184 4 x Slide Beam2424-248 4 x Slide Beam2424-312
MakerSpace Kits2.0-Connecting Fittings
24 x Brakcet 3*3 16 x Bracket 3*6 16 x Plate 3*6 16 x Plate 7*9-B
16 x Plate l1 16 x Plate O1 16 x Plate A 16 x Triangle Plate 6*8
16 x Plate45° 16 x Bracket L1 16 x Bracket U1 16 x Bracket U-B
8 x Disc D72 8 x Bracket P1 8 x Bracket P3 48 x Cuttable Linkage
24 x Cuttable Linkage 3 Hole 8 x Stiffener 1616-008-M4 8 x Plate0324-040 8 x Plate0324-056
16 x Plate0324-072 16 x Plate0324-088 16 x Plate0324-184 24 x Plate 3*5*120
24 x Bracket 3*3*120 8 x Bracket U-C
MakerSpace Kits2.0-Large Parts
4 x Lean Beam-424 4 x Lean Beam-504 4 x Slide Beam-424 4 x Slider 496(Blue)
4 x Beam0808-504(Blue) 6 x Slide Beam0824-496 4 x Shaft D8*512mm-H 6 x Shaft D8*496mm-H
2 x 360*256mm Aluminium Sheet 2 x Base Plate- S(Blue)
MakerSpace Kits2.0-Hardwares and Tools 1*2
400 x Socket Cap Screw M4*8-Button Head 100 x Socket Cap Screw M4*40-Button Head 100 x Socket Cap Screw M4*35-Button Head 100 x Socket Cap Screw M4*30-Button Head
100 x Socket Cap Screw M4*22-Button Head 200 x Socket Cap Screw M4*16-Button Head 400 x Socket Cap Screw M4*14-Button Head 60 x Cross Recess Screw M3*8-Countersunk Head
100 x Plastic Spacer 4*8*1 100 x Plastic Spacer 4*7*3 200 x Plastic Spacer 4*7*2  40 x Plastic Spacer 4*7*10
120 x Plastic Rivet R4120(White) 120 x Plastic Rivet R4100(White) 120 x Plastic Rivet R4060(Black) 80 x Tapping Screw with Washer M2.2*9.5-Round Head
20 x Nylon Stud M4*30 10 x Velcro sticker pad 40 x Nylon Cable Ties1.9*100 20 x Hex Nut M8
400 x Hex Nut M4 200 x Hex Nut M3 200 x Hex Lock Nut M4 100 x Cross Recess Screw M3*25-Button Head
100 x Cross Recess Screw M3*16-Button Head 4 x Cross &2.5mm HEX Screwdriver V2.0 40 x Brass Stud M4*8+6 24 x Brass Stud M4*32
40 x Brass Stud M4*16 6 x Wrench M5+M7 8 x HEX Allen Key 1.5mm 8 x HEX Allen Key 2.5mm
100 x Headless Screw M3*5 2 x 2 Inch G-clamp
MakerSpace Kits2.0-Hardwares and Tools 2*2
100 x Headless Screw M3*8 200 x Combination Screw M4*8 200 x Combination Screw M4*10 200 x Combination Screw M4*14
400 x Combination Screw M4*16 400 x Combination Screw M4*20 200 x Combination Screw M4*30 400 x Combination Screw M4*35
200 x Combination Screw M4*40 200 x Hex Lock Nut M3 4 x Small Four-way socket wrench 4 x Rapid Steel Allen Driver 1.5mm(Black)
4 x Rapid Steel Allen Driver 3mm(Black) 600 x Hex Nut M4 200 x Hex Lock Nut M4 8 x Brass Stud M4*25+6 (Pack of 4)
8 x Brass Stud M4*16+6 (Pack of 4)
MakerSpace Kits2.0-Basic Drive Parts 1
8 x Timing Belt 140T(112MXL) 8 x Timing Belt 300T(240MXL) 6 x Timing Belt-Open end(5m) 8 x Belt Connector-B
8 x Belt Connector 8 x Timing Pulley Slice 90T-B 8 x Timing Pulley Slice 62T-B 8 x Plastic Timing Pulley 18T
4 x Timing Pulley 90T 4 x Timing Pulley 62T 4 x Fully Threaded Rod M4*192 4 x Fully Threaded Rod M4*288
4 x Fully Threaded Rod M4*248 8 x Thread Drive Beam M4*40 8 x Sliding Block A1 32 x Aluminum Sleeve4*6*4
32 x Aluminum Sleeve 4*6*6 32 x Roller(With Bearing) 16 x Nylon Wheel( No Bearing) 8 x V-slot Bearing 4*136
4 x Slider 256
MakerSpace Kits2.0-Basic Drive Parts 2
4 x Gear 16T 4 x Gear 48T 4 x Gear 80T 16 x Double gear Rack
16 x Plastic Gear 8T 16 x Plastic Gear 56T 32 x Plastic Gear 72T
MakerSpace Kits2.0-Shaft Type Drive Parts
20 x D Shaft 4*56 8 x D Shaft 4*128 12 x D Shaft 4*160 8 x Shaft 8*96-H
8 x Shaft 8*128-H 8 x Shaft 8*312-H 24 x Shaft 4*88 8 x Shaft 4*240
8 x Shaft 4*288 8 x Linear Box Slider D8 100 x Flange Bearing 4*8*3 20 x Bearing 4*8*3
20 x Bearing 8*16*5 16 x Threaded shaft 4*39 80 x Shaft Collar 4mm 40 x Shaft Collar 8mm
8 x Universal Joint 4*4 20 x Bearing F688ZZ 30 x Shaft Connector 4mm 16 x Flexible Coupling 4*4
8 x Shaft Clamping Hub 8mm 16 x 8mm Bearing Bracket A 30 x Shaft Connector 4mm V3.0
MakerSpace Kits2.0-Motion Parts 1
16 x Plastic Timing Pulley 62T 16 x Plastic Timing Pulley 90T 8 x Plastic Timing Pulley 62T For Motor 16 x Plastic Timing Pulley 90T For Motor
16 x Tyre 68.5*22mm 8 x Slick Tire 8 x Mini Caster Wheel
MakerSpace Kits2.0-Motion Parts2
200 x Track 200 x Track Axle 4 x 58mm Omni Wheel Coupling Pack 4 x 1 Inch Nylon Pulley
8 x 58mm Omni Wheel
MakerSpace Kits2.0-Servos
8 x 9g Micro Servo Robot Pack 4 x RJ25 Adapter 8 x Smart Servo MS-12A 8 x Rudder Bracket
8 x Terminal Wire-20cm 8 x Terminal Wire 60cm 8 x Mounting Bracket 8 x Virtual Axis
4 x MEDS150 Servo Motor 8 x Color Number Sticker
MakerSpace Kits2.0-Motor Modules 1
8 x Geared Motor DC6V/312RPM 4 x Me 130 Motor Pack-5V/10000RPM
MakerSpace Kits2.0-Motor Modules 2
4 x DC Motor-37 12V/50RPM 4 x DC Motor-37 12V/200RPM 4 x DC Motor-25 9V/185RPM 4 x Optical Encoder Motor-25 9V/185RPM
MakerSpace Kits2.0-Motor Modules 3
16 x DC Motor-25 Bracket 16 x DC Motor-37 Bracket 8 x Dual Motor Driver 32 x PH2.0 Motor Cable
8 x 180 Optical Encoder Motor 8 x Dual Motor Driver 4 x Encoder Motor Driver 8 x High-Power Encoder /DC Motor Driver
8 x 2. 54mm 6P Encoder Motor Cable 8 x MegaPi Pro Encoder/DC Motor Driver 8 x 25 Encoder Motor Cable
MakerSpace Kits2.0-Motor Modules 4
2 x Air Pump Motor-DC 12V/370-02PM 2 x Solenoid Valves DC 12V/0520E 2 x Water Pump Motor-DC 12V370-04PM 2 x Silicone Air Tube 0507
2 x Vacuum Suction Head M4 2 x Silicone Air Tube 0305 2 x Vacuum Suction Cup-SP-30 2 x Mini Gripper
4 x Robot Gripper-Black
MakerSpace Kits2.0-Motor Modules 5
4 x 42BYG Stepper Motor Bracket-B 4 x 42BYG Stepper Motor 4 x Me Stepper Motor Driver 2 x Brushless Motor
4 x MegaPi Pro ESC Driver V1.0 4 x Friction Wheel D45*19.5 4 x Friction Wheel Ring D28*7 4 x Megapi Stepper Motor Driver
MakerSpace Kits2.0-Motion Parts 3
8 x 100mm Omni Wheel 8 x 100mm Omni Wheel Coupling 40 x Cuphead Screw M5*40 40 x Lock Nut M5
MakerSpace Kits2.0-Chain Transmission Parts
4 x 04C 20T Sprockets 2 x 04C 14T Double Sprockets 4 x 04C 10T Sprockets 4 x 04C Roller Chain-1.5
2 x 04 Chain Rivet Extractor 2 x 04C Half Chain Unit 2 x 04C Chain Unit 4 x 04C One-hole Bending Chain
16 x Headless Screw M3*5 16 x Headless Screw M5*5 8 x Shaft 8*96-H 8 x Shaft Collar 8mm
4 x Bracket U-B
MakerSpace Kits2.0-MakeX Electronic Modules
8 x Dual RGB Color Sensor 8 x Ranging Sensor 2 x Power Expansion Board 16 x PH2. 0 Motor Cable
2 x Me Power Management Module 2 x Main Board NovaPi 8 x Smart Moter Cable-60CM 12 x 5V General Cable-20cm
2 x Low Voltage Buzzer Alarm 4 x Bluetooth Module 2 x XT60 XT30/DC One with Three Power Cords 12 x 5V General Cable-60cm
MakerSpace Kits2.0-MakeX Batteries
4 x Lithium Battery 4 x 18650 Lithium Battery Pack 2 x FB4300HP-3SLI-PO Battery
MakerSpace Kits2.0-MakeX Motor Modules
1 x Skyr B6AC V2 4 x x180 Smart Encoder Motor 2 x xNovaPi Case 4 x 36 Encoder Motor-Brushless
Gratnells Shallow Tray, CyanBlue (Pack of 4)*2
8 x Gratnells Shallow Tray, CyanBlue
Lid for Standard Trays, Translucent (Pack of 4)*2
8 X Lid for Standard Trays, Translucent
Gratnells Tray Runners with Clips for Trays (Pack of 6 pairs)*7
42 x tray clips 42 x runners
Customer Reviews
No reviews yet
0%
(0)
0%
(0)
0%
(0)
0%
(0)
0%
(0)
Customer Reviews
No reviews yet
0%
(0)
0%
(0)
0%
(0)
0%
(0)
0%
(0)
x
Social Proof Apps
