No Products in the Cart
Makeblock is an open-source construction platform that turns your ideas into reality, no matter what your idea is and however impossible it looks like. Makeblock will make it possible by providing various mechanical parts, electronic modules, and software. Makeblock has become one of the best intelligent hardware companies that strive to make difference.
Feature
Me Line Follower V2.2 module is designed for the line following robotics. It has two sensors on the module and each sensor contains two parts – an IR emitting LED and an IR sensitive phototransistor. It can output a digital signal to Arduino so the robot can reliably follow a black line on a white background or vice versa.
Detecting range: 1~2cm
Dimensions:2.4cmx4.8cm
You do not have permission to view this page
Please contact ecommerce.hk@makeblock.com for assistance or refresh the page to retry. If you are using a VPN please disable it.
