10-in-1 Ultimate Robot Best Deal Bundle
    Black Friday offer ends Nov 26
    $389.99 $499.99
    fullfill by amazon
    fast-fulfilled by Amazon
    30-day money back
    lifetime support
      Uses code BLACK30 for 30% OFF!
      This bundle includes:
      1. 10-in-1 Ultimate Programmable Robot>  (org: $399.99)
      2. Bluetooth Remote Controller Joystick> (org: $49.99)
      3. Electronic Add-on Pack> (org: $29.99)
      10-in-1 Programmable Robot Kit
      10 Building Forms For
      All Your DIY Need
      Ultimate 2.0 has an impressive parts library, boasting more than 550 mechanical and electronic items, it provides a comprehensive range of features and includes everything you need for realizing your ideas. To give you a head start and allow you to learn the ropes of applied electronics and mechanical principles, 10 practical and interesting forms of construction are provided, including the Camera Dolly and Robotic Bartender. The possibilities for maker combinations is infinite, you can truly let your imagination loose.
      10 Building Forms For All Your DIY Need
      Safe, Durable & Easy for DIY
      Most of the parts of Ultimate 2.0 are made of high-strength aluminum alloy. This makes the material light, strong and durable. The anodizing dyeing process is also environmentally friendly and non-toxic, and both enhance their appearance and prolongs their lifespan. Ultimate 2.0 has a standardized interface compatible with other building bricks, maker platforms, and industry-standard parts, which means you can use it to build quasi-industrial projects.
      Ultimate 2.0 Parts Library
      Mainboard MegaPi with
      powerful Drive Capability
      Empowering Creativity
      Equipped with the powerful MegaPi main control board, Ultimate 2.0 makes the implementation of high-order functions a piece of cake. Think: synchronous drive and control of multiple motors and servos, sensor reading, Raspberry Pi communication and connection to high-power encoder motor driver boards. MegaPi has excellent motion control performance and is easily expanded, allowing you to build robots capable of carrying out complex functions like 3D printing, or even more difficult applications. With it, the door to the world of Making stands wide open for you.
      Interfaces of MegaPi and other Plug-in Modules
      MegaPi has a strong motor-driving ability which is capable of driving 10 servos or 8 DC motors simultaneously. It is an ideal option for various robotic projects.
      Further Explore The Maker’s World
      Ultimate 2.0 supports all of the various electronic components of the Makeblock RJ25 platform. You can purchase additional sensors and motor servos for more upgrades, allowing you to expand your ideas and further explore the Maker’s world. For example, a 3D printer, a retro phonograph, or other complex elements of robotics.
      Further Explore The Makers' World
      Easy Transition from graphical Programming
      to Python Programming
      Program Ultimate 2.0 using the Makeblock App
      Switch from graphical to text-based programming via the mBlock 5
      mBot Ultimate FAQs
      Customer Reviews
      No reviews yet
      0%
      (0)
      0%
      (0)
      0%
      (0)
      0%
      (0)
      0%
      (0)
      BACK TO TOP
      /products/ultimate-robot-best-deal-bundle
      Social Proof Apps
