xTool D1- Higher Accuracy Portable Diode Laser Engraving & Cutting Machine
    Use code【NEW10】for extra $10 OFF!
    $796.00 $1,016.00
    fullfill by amazon
    fast-fulfilled by Amazon
    30-day money back
    lifetime support
      PAYMENTS payment icons
      SOFTWARE SUPPORT:
      • Third-Party Engraving software: LightBurn
      • Our beginner-friendly software: Laserbox Basic, allows you to work seamlessly on Windows / macOS / Android / iOS devices, engraving file format supports SVG/DXF/JPG/JPEG/PNG/BMP/TIF/CR2, etc.
      * You can click here to learn more.
      SHIPPING:
      • Due to the New Year's Day holiday, orders from Dec 24 to Jan 3th will start shipping on Jan 4 and be delivered within 5-13 business days.
      • The rotary attachment and risers will be shipped separately.
      Laserbox Rotary
      xTool D1
      Higher Accuracy DIY Laser Engraving & Cutting machine
      Best Downsized Industrial High Power Laser Engraver & Cutter for business starters/hobbyists/designers/artists/home-makers/professionals.
      Better technologies (industrialized steel wheel&shaft/tension wheel/synchronous belt/Compressed light spot,etc.) makes the carving more precise and the carved works perfect. With more humanized designs, you can concentrate on your creation all the time.
      Laserbox Rotary
      xTool D1
      Better Mechanical Design Increases Accuracy
      Industrialized steel wheel&shaft
      With professional motion structure design, we adopt industrialized steel for both axle and wheel, making it up to 160mm/s motion speed more accurately.
      Also making D1 longer product lifetime.
      Higher accurate
      Tension wheel & Synchronous belt
      By tightening the synchronous belt with the tension wheel adjuster, the movement gap is well eliminated, the machine vibration is reduced and the movement stability is improved, so that the engraving remains accurate even at high processing speeds.
      Higher accurate even at high processing speeds
      Higher Repeat Positioning Accuracy
      Optimized powerful 40W CO2 laser tube. Lightning fast cutting and engraving speeds up to 350mm/s, with a cutting depth of up to 15mms.
      A pin point 0.05mm laser beam, cleanly cuts a wide range of materials, from wood and cardboard to acrylic and many other materials in between.
      A large enclosed design gives you a 490mm * 290mm space to create to your heart's content!
      The revolutionary features that set Laserbox Roatay apart
      Better Laser Enhances Cutting & Engraving Effect
      The ultra-fine laser focus area
      Applying the advanced laser spot technology, the laser spot accuracy reaches 0.08mm, stronger than many other laser cutting machines.
      With the 0.08mm thin laser spot and 0.01mm ultra-high movement precision, it ensures more accurate cut lines and fewer burn marks.
      Innovative Twin Beam Design
      Combine the beams of 2 laser modules to achieve 10W laser output.
      The processing speed reaches 160mm/s,  easy to cut 6mm basswood, creating more efficiency.
      More Function
      Customize a wide range of cylindrical materials with the rotary accessory attachment. (sold separately)
      432 * 406 mm (17 * 16 inch) Large engraving range to meet your various engraving needs.
      Height Adjustment
      Using additional raisers to increase the height of xTool D1 to facilitate the engraving of higher objects. Customize your skateboard or basketball to make them cooler.
      Quickly connect the xTool D1 to your smartphone/computer/tablet via WiFi, upload pictures to the Laserbox basic software, edit them according to your needs, and complete the processing in a few simple steps.
      Quickly connect the xTool D1 to your computer via USB when the internet connection is bad.
      The xTool D1 supports a large-capacity TF card. After sending the files, you can put your device aside and easily realize the cutting/engraving/batch processing by clicking the button at any place.
      Better Software at Your Service
      xTool Software: Supports multiple devices and multiple formats
      Equipped with specialized software, xTool D1 allows you to work seamlessly on Windows / macOS / Android / iOS devices.
      Learn More about Software
      Better Design and More User Friendlly
      Easy focus adjustment
      Newly designed laser module adjustment function. The laser module can be adjusted up and down to fit various thicknesses of materials through slots and screws. The original focus lever enables easy autofocusing.
      Modular Construction
      Assemble the machine in about 10 minutes. Easy to assemble and easy to disassemble. The device weighs less than 6 kg and is portable and easy to carry.
      PARTS LIST
      Package Included
      1 x 12V 7A Power Adapter
      1 x USB Cable
      2 x Connection Cable
      1 x Goggles
      1 x Leather Label (gift)
      1 x Basswood Board (gift)
      1 x Aluminium Sheet (gift)
      1 x Stainless Steel Pet Tag (gift)
      1 x TF Card
      10 x Rolled Belts
      3 x Hexagonal Spanner
      1 x Instruction Card
      16 x Screw M4*8
      4 x Screw M4*15
      3 x Screw M4*25
      Unleash your creativity on hundreds of finest materials, and it shows!
      Specs
      MODELSxTool D1 - 5WxTool D1 - 10W (Best Seller)
      LASER SYSTEM
      Machine Power
      36W60W
      Laser Electric Power25W40W
      Laser Module Output Power5W10W
      Laser Spot0.08  mmsame
      Wavelength450 - 460 mmsame
      Routing Speed160 mm/ssame
      WORKING AREA
      Working Area432 * 406 mm (17 * 16 inch)same
      Max. Workpiece Height50 mmsame
      MISCELLANEOUS
      Voltage Input100-240V  50-60HZsame
      Voltage Output12V  7A  84Wsame
      Connecting InterfacesUSB/Wi-Fisame
      CertificationFCC/FDAsame
      SOFTWARE DEQUIREMENTS
      Operating SystemsWindows/macOS/Android/iOSsame
      Control SoftwareLaserbox Software/ Laserbox Appsame
      File Type(s)SVG/DXF/JPG/JPEG/PNG/BMP/TIF/CR2, etc.same
      SIZE AND WEIGHT
      Product Weight5kg
      Package Weight6kg
      Product Size (L * W * H)600*590*150 mmsame
      Package Size (L * W * H)620*345*130 mmsame
      LASER SYSTEM
      Beam Type
      Single BeamTwin Beams
      Machine Power
      36W60W
      Laser Spot0.08 * 0.08 mmsame
      WORKING AREA
      MISCELLANEOUS
      CertificationCE/FCC/FDAsame
      SIZE AND WEIGHT
      Product Weight5kg
      Package Weight6kg
      Our stories
      xTool is part of Makeblock, a world-renowned coding robot manufacturing & education company.
      So our story actually started with a lot of love and a little inspiration:
      how to make it easier and safer for kids to engrave and cut out their doodle drawings?
      Check out what people say about xTool!
      We take pride in our quality and service, also inspired by your story!
      Unboxing & User Guide
      xTool Laserbox — Bring Sketch to Life
      Adam tries a 40w CO2 Laser-Cutter! Makeblock Laserbox REVIEW
      You may be wondering
      Unlimited Possibilities with xLight
      Learn more about xLight
      Customer Reviews
      Based on 1 review
      100%
      (1)
      0%
      (0)
      0%
      (0)
      0%
      (0)
      0%
      (0)
      R
      Roger Wolfe
      Great first experience
      Easy to assemble, instructions great and easy first time software for beginners
      Trusted Technology Partners
      This t-shirt is everything you've dreamed of and more. It feels soft and lightweight, with the right amount of stretch. It's comfortable and flattering for both men and women.
      • 100% combed and ring-spun cotton (heather colors contain polyester)
      • Fabric weight: 4.2 oz (142 g/m2)
      • Shoulder-to-shoulder taping
      • Side-seamed
      The Male model is wearing a size M. He's 6.2 feet (190 cm) tall, chest circumference 37.7" (96 cm), waist circumference 33.4" (85 cm).
      The female model is wearing a size M. She's 5.8 feet (178 cm) tall, chest circumference 34.6" (88 cm), waist circumference 27.16" (69 cm), hip circumference 37.7" (96cm).
      CUSTOMERS TESTIMONIALS
      “The Quality is excellent. Printing is also excellent. I'm very pleased! you guys rock! More orders coming your way.”
      By Maurice Jackson
      Way better quality than expected! I had a huge, complex graphic printed on it as well, and the print quality was great! Not too thick, and very stretchy.. highly recommend.
      By David A Love
      I absolutely love these shirts! They are so soft and comfy, and the print quality on
      them is fantastic!
      By Andrea Brown
      BACK TO TOP
      /products/xtool-d1-portable-diode-laser-machine-for-laser-engraving-laser-cutting
      Social Proof Apps
