No Products in the Cart
Higher Accuracy DIY Laser Engraving & Cutting Machine
Meet All Your Needs
Working Speed
Increase Your Productivity at the Highest-Speed
With the upgraded algorithms, the routing speed can reach up to
400mm/s
Structure
ALL-Metal Made,
All-Time Accurate
Aluminum Plates & Steel Timing Pulley and Shafts
Eliminate Machine Vibrations by Tightening Up the Synchronous Belt
*First Designed and Used by xTool
The solid STEEL stabilizes the structure, allowing for:
engraving/cutting accuracy to reach 0.004 inches
repositioning accuracy down to less than 0.007 inches.
Focus Adjustment
Easily and Precisely Adjust the Focus
Fix the Focus
Pull down the focal length setting bar, and adjust its distance to the material by sliding up or down the entire laser module
Limit Switches
Limit Switches Auto-Identifying Boundaries in All Directions
Limit switches on both the X and Y axis can accurately locate the working coordinates of the laser head, updating you on the processing progress in software.
They will also trigger the alarm if the laser head is about to hit the boundary of the machine.
Color Engraving on Metal
Invigorate Your Creations with 340+ Colors
*The color varies from different materials in different environments on different parameters.
Super powerful 20W laser beam oxidizes the metallic surface in an instant, bringing vivid colors to the engraved metal.
The color of the metal engraving will no longer be limited to black/grey. Your creativity will be brought to the next level with 340+ colors.
Safety Features
Instant Stop Processing for Extra Safety
Instant Stop when machine detects flames
Instant Stop when machine is moving or tipping
Software
Compatible with Software of All Levels
Updating Project Files
Image Editing
Batch Processing with Circular Array
Default Working Parameters for Materials
Compatible with mature engraving software: LightBurn
The layout, editing, and control software for common laser cutter. Engraving file format supports NC, BMP, JPG, PNG, DXF, etc.
xTool RA2 Pro
Versatile Cylinder Engraving
RA2 Pro (Sold Separately): The WORLD'S FIRST 4-in-1 Rotary for laser Engraver, suitable for irregular cylinder and sphere objects, like tumblers, mugs and rings
· Roller Rotary · Chuck Rotary · Sphere Rotary · Ring Rotary
Functional Designs
Details Matter
Minimize Lens Pollutions by Optimizing Air Outtake
New structural design of the light shield prevents laser lenses polluting by smoke and reducing dust accumulations inside the shield.
Large Engraving Area
A large working area of 430*390 mm ( 17*15.4 inch ), more than the size of A3 paper, allows you to engrave more patterns at once. Easy to use and more efficient.
The Risers
Use additional risers (sold separately) to increase the height of xTool D1 Pro to facilitate the engraving of higher objects(use 2 sets to increase height to 140mm). Customize your skateboard or basketball to make them cooler.
Just Connect
You can transfer data via Wi-Fi, USB cable, a large capacity TF card (Offline Use) and use D1 Pro anytime and anywhere.
Just Connect
You can transfer data via Wi-Fi, USB cable, a large capacity TF card (Offline Use) and use D1 anytime and anywhere.
Specs
xTool D1 Pro 10W/20W VS xTool D1 10W/20W
xTool D1 Pro 10W/20W | xTool D1 10W/20W | |
Working Speed | 400mm/s | 160mm/s |
Compression Spot | 0.08*0.1mm | 0.08*0.15mm |
Working Area | 430*390 mm | 432*396mm |
Laser Head | 1. Suppot Focal Length Adjustment: Focal point can sink down to the middle of the thicker materials, to get better cutting results
2. Optimizing the Structure of Air Outtake to Minimize Lens Pollutions 3. Built in Air Nozzle (Air Pump Not Included) | / |
Limit Switches | Auto-Identify 4 Boundaries Covered by 4 Limit Switches | / |
Safety Features | Trigger the alarm and Instant Stop Processing, if the machine detects flames or moving/tipping | / |
Part List
