No Products in the Cart
Made by xTool D1 Pro
Cutting Board
Acrylic Earings
Tumbler
xTool D1 Pro Supports 100+ Materials
Ultrafine Lines with Compressed Spot Tech
Smaller laser focus (from 0.15*0.15mm to 0.08*0.06mm) makes impeccable detail, thanks to compresssed spot tech
100% Duplicate and Reprint Your Design
Structure
ALL-Metal Made,
All-Time Accurate
Aluminum Plates & Steel Timing Pulley and Shafts
Eliminate Machine Vibrations by Tightening Up the Synchronous Belt
*First Designed and Used by xTool
The solid STEEL stabilizes the structure, allowing for:
engraving/cutting accuracy to reach 0.004 inches
repositioning accuracy down to less than 0.007 inches.
Limit Switches
Limit Switches Auto-Identifying Boundaries in All Directions
Limit switches on both the X and Y axis can accurately locate the working coordinates of the laser head, updating you on the processing progress in software.
They will also trigger the alarm if the laser head is about to hit the boundary of the machine.
Focus Adjustment
Easily and Precisely Adjust the Focus
Fix the Focus
Pull down the focal length setting bar, and adjust its distance to the material by sliding up or down the entire laser module
Safety Features
Instant Stop Processing for Extra Safety
Instant Stop when machine detects flames
Instant Stop when machine is moving or tipping
Software
Compatible with Software of All Levels
Updating Project Files
Image Editing
Batch Processing with Circular Array
Default Working Parameters for Materials
Compatible with mature engraving software: LightBurn
The layout, editing, and control software for common laser cutter. Engraving file format supports NC, BMP, JPG, PNG, DXF, etc.
xTool RA2 Pro
Versatile Cylinder Engraving
RA2 Pro (Sold Separately): The WORLD'S FIRST 4-in-1 Rotary for laser Engraver, suitable for irregular cylinder and sphere objects, like tumblers, mugs and rings
· Roller Rotary · Chuck Rotary · Sphere Rotary · Ring Rotary
Functional Designs
Details Matter
Minimize Lens Pollutions by Optimizing Air Outtake
New structural design of the light shield prevents laser lenses polluting by smoke and reducing dust accumulations inside the shield.
Large Engraving Area
A large working area of 430*390 mm ( 17*15.4 inch ), more than the size of A3 paper, allows you to engrave more patterns at once. Easy to use and more efficient.
The Risers
Use additional risers (sold separately) to increase the height of xTool D1 Pro to facilitate the engraving of higher objects(use 2 sets to increase height to 140mm). Customize your skateboard or basketball to make them cooler.
Just Connect
You can transfer data via Wi-Fi, USB cable, a large capacity TF card (Offline Use) and use D1 Pro anytime and anywhere.
Just Connect
You can transfer data via Wi-Fi, USB cable, a large capacity TF card (Offline Use) and use D1 anytime and anywhere.
Specs
Type | xTool D1 Pro-20W | xTool D1 Pro-10W | xTool D1 Pro-5W |
Machine Power | 120W | 60W | 36W |
Laser Electric Power | 84W | 40W | 25W |
Laser Module Output Power | 20W | 10W | 5W |
Laser Spot | 0.08*0.10mm | 0.08*0.06 mm | 0.06*0.06 mm |
Routing Speed | 400 mm/s | 400 mm/s | 400 mm/s |
Working Area | 430 * 390 mm (16.93 * 15.35 inch) | 430*400 mm(16.93*15.75 inch) | 430*400 mm(16.93*15.75 inch) |
Max. Workpiece Height | 50 mm (2 inch) | 50 mm (2 inch) | 50 mm (2 inch) |
Max. Workpiece Height with X risers | 50mm+X*45mm(each set riser height column) | 50mm+X*45mm(each set riser height column) | 50mm+X*45mm(each set riser height column) |
Connecting Interfaces | USB/Wi-Fi/TF Card | USB/Wi-Fi/TF Card | USB/Wi-Fi/TF Card |
Certification | FCC / FDA / CE | FCC / FDA / CE | FCC / FDA / CE |
Operating Systems | Windows/macOS/Android/iOS | Windows/macOS/Android/iOS | Windows/macOS/Android/iOS |
Control Software | xTool Creative Space / LightBurn | xTool Creative Space / LightBurn | xTool Creative Space / LightBurn |
File Type(s) | SVG/DXF/JPG/JPEG/PNG/BMP/TIF/CR2, etc. | SVG/DXF/JPG/JPEG/PNG/BMP/TIF/CR2, etc. | SVG/DXF/JPG/JPEG/PNG/BMP/TIF/CR2, etc. |
Compatible Accessories | RA2 Pro Air Assist Set xTool Smoke Purifier Honeycomb Working Panel Set Enclosure xToolCare for xTool D1 Pro 20W RA1 | RA2 Pro Air Assist Set Smoke Purifier Honeycomb Working Panel Set Enclosure xToolCare for xTool D1 Pro 10W RA1 | Same With xTool D1 Pro-10W |
xTool D1 Pro 5W VS xTool D1 5W
xTool D1 Pro-5W | xTool D1-5W | |
Working Speed | 400mm/s | 160mm/s |
Compression Spot | 0.08*0.06mm | 0.08*0.08mm |
Working Area | 430*400mm | 432*406mm |
Laser Head | 1. Suppot Focal Length Adjustment: Focal point can sink down to the middle of the thicker materials, to get better cutting results
2. Optimizing the Structure of Air Outtake to Minimize Lens Pollutions 3. Built in Air Nozzle (Air Pump Not Included) | / |
Limit Switches | Auto-Identify 4 Boundaries Covered by 4 Limit Switches | / |
Safety Features | Trigger the alarm and Instant Stop Processing, if the machine detects moving/tipping | / |
Part List
