No Products in the Cart
Normally, a laser cutter can perform very well on many materials such as wood, metal and glass. However, for some soft materials such as vinyl, which can be used for DIY T-shirts, sign making, logos and more, a blade cutter is preferable to avoid the burnt edge, discoloration and toxic fumes generated by laser cutting.
With xTool M1 which has both the laser and blade heads, you don’t have to waver between a laser cutter or a blade cutter (or breaking the bank to buy both). Your ideas can be realized on just one machine.
What You Can Create with xTool M1
Small, Powerful and Accurate
Powerful Enough to Cut Basswood up to 8mm in One Pass
Smart and Easy to Use
16 MP Smart Camera
Equipped with a 16MP high resolution camera inside, xTool M1 can realize visual processing and smooth operation.
Image Extraction
xTool M1 intelligently captures images, designs, and drawings from any surface and then imports them into xTool’s graphic design software for further creative design.
Batch Processing
The AI system automatically detects the shape of the material and processes the same shape of the material in batches at one time.
AI Auto-focus
xTool M1 initiates auto-focusing, including visual identification, material thickness settings and material recognition so you don’t have to set the cutting parameters by yourself.
What's inside the box?
Official Live Demo of xTool M1
If you have any further questions, please feel free to contact us via hello@xtool.com.
Or join our Facebook community to discuss with over 13000 M1-loving crafters & handmade store owners!
